Anyone know if these are any good
  • bigcooler
    • Jan 2009
    • 229
    any one know if these are any good for 450+hp or if they are not worth the risk?
    http://www.ebay.co.uk/itm/AUDI-VW-Ro...item27be7230ed
  • willg54
    • Jun 2009
    • 2055
    with stuff like that, i always go with "you get what you pay for" and im sure for 450bhp, you dont want to be cutting corners. will just cost you more in the long run!
    • bigcooler
      • Jan 2009
      • 229
      ok thanks for the heads up, dont realy fancy building it twice
      • willg54
        • Jun 2009
        • 2055
        someone may have a definitive answer though... thats just my thoughts!
          If they are Kolbenschmidt as the box suggests then they are good quality bearings.
          • DS2
            • 80
            • Home: Jordan Current: Finland
            i agree if they are what the box says then thy are ok
            • aelred
              • Jan 2005
              • 761
              KS spatters are good
              Aelred
              • SteveH
                • 4460
                It would be worth checking that you are actually receiving KS bearings. If so, they are fine. Get the part number from the seller to see if they are spatter type. Not sure how the price compares to other sources?
                91 Modded 3B
                14 A6 Avant Black Edition
                  Its in the ballpark for a set of decent rod bearings, more expensive than the Glycos anyway. Might be worth getting them off a UK supplier so you have backup & comeback if they are incorrect, faulty etc. Just my 2c
                  • 220bhp
                    • 2578
                    • Home: United Kingdom
                    I have a set of both mains and big end KS bearings coming up fo rsale soon, in 0.50 big end and 0.25 in mains that I bought from Pete at Quattro corner.I also have the crank which is ground to take them. These where for my rebuild.but Alered had a crank for sale that was standard,and had some work done on it,so I used that in stead.
                    • bigcooler
                      • Jan 2009
                      • 229
                      any idea where i can get suitable internal parts for 450+ i.e mains, big ends, rings,water pump, also is there a little end bearing? havnt split my ABY block yet to see
                      • 220bhp
                        • 2578
                        I gotmost of my stuff from Aelred hes on this forum,top bloke
                        • bigcooler
                          • Jan 2009
                          • 229
                          ideal thank you
                          • bigcooler
                            • Jan 2009
                            • 229
                            hi guys i sent an email to the seller saying:
                            HI ARE THESE ROD BEARINGS GENUINE Kolbenschmidt OR COPY'S? ALSO ARE THE MAIN BEARINGS YOU HAVE GENUINE Kolbenschmidt?
                            thanks Ben
                            And got the response:
                            all of the bearins are Kolbenshmidt
                            - davis_natrins
