Fuel pump change to more efficient one
  • audi4fun
    • Mar 2006
    • 111
    • Country: Latvia
    Hi guys,
    Please advice how to fix new fuel pump into housing. New one is shorter and has less diameter.
    Thanks!
    Owner of www.audiScars.lv
    ex-Audi S2 Coupe '96
    ex-Audi S2 Coupe '93
    ex-Audi S2 Coupe '91
    You will need to either use a petrol/gasoline compatible rubber spacer or machine an aluminum spacer. Neoprene rubber *might* work (check out its compatibility with fuel). If that is a Walbro pump a) good luck and b) 034 might make a spacer to fit it into the 43 mm diameter basket.
    • darkhorse1210
      • May 2010
      • 335
      I have an OEM Pierburg fuel filter for sale....it's OEM for the RS2, so could check if it's OEM for the S2 also if interested?
      Tom
      • audi4fun
        • Mar 2006
        • 111
        • Country: Latvia
        Thanks. What do you mean with good luck?
        This is not Walbro.
        • darkhorse1210
          • May 2010
          • 335
          Sorry, I meant Fuel Pump not filter
            This is not Walbro.
            Some Walbros, have, well, "failed to function as required", to put it nicely.
            • audi4fun
              • Mar 2006
              • 111
              • Country: Latvia
              Thanks for advice. Job done.
                If you machined that spacer/retention ring and the pump works better than stock, i.e. more flow and more pressure, you might have a market for making more.
                I take it the second pump retention clip broke off your basket:
