All MAF's are the same. RS2, AAN etc.
All ECU's are the same as well, except for MAP sensor, R201 and other changes not related to engine management.
The question is whether these chips used RS2 software as base or AAN. You won't know that unless you understand the software and can compare MAF calibration.
Also, 2 bar boost mapped properly on safe rods is much safer than 1.6 bar on lotto chips.
