Injectors - any good??
  • europeanme
    • Oct 2005
    • 3817
    http://www.ebay.com/itm/5-EV14-Volvo...item5643cf7991
    i am aiming at 500hp....hoping more like but these shouldn't run out of steam...I realise they are AAN fitment but they cannot be that different to ABY...or are they..
    any tips welcome....
    cheers
    Mike
    Ev14 yeah the best, I'd check they are the 60mm versions as I haven't seen the 60mm for sale before even though we know they exist
    Bit big for your needs though I run the same size in my stroker, but you wouldn't need to upgrade again
    • europeanme
      • Oct 2005
      • 3817
      how do you know what my needs are???.... :mischeif:
      I will ask them the length question...is it only 60mm which can be used?...
        Because you said 500 bhp in the 1st post
        The shorter ev14 need adapters or change in fuel rail
        • europeanme
          • Oct 2005
          • 3817
          indeed i did....
          when you say change in fuel rail, will the Nuke version work?....or the adaptors from Finjector?....
            Both obviously adapters is easiest method
            • europeanme
              • Oct 2005
              • 3817
              can i assume they are the same adaptors you, Ross, AndyP and Vas have used?...I have been sent the link...cheers Ross...
              does anyone have the part number/dimensions of Bosch parts?....
