Dumb engine question???
  • s4boy
    • Dec 2010
    • 103
    Still in the learning stage re 20 v engine, been reading a few build threads and a torque plate is used for the honing stage, now for the silly new boy question what is it and what does it do when boring / honing, sorry in advance............mark
  • pasbogdan
    • Sep 2009
    • 1160
    • Country: Romania
    It is suposed that block changes its shape when head is torqued.That way you hone/bore exactly like the block will be when head is on.This is my expl.If there are more...
    • s4boy
      • Dec 2010
      • 103
      Cheers thank you I see how it works now.......mark
      • JP
        • 1858
        When you torque down a head it pulls the top of the bores square corresponding to the headbolts locations. Realistically its not a major essential process on the I5 engine if you haven't access to one as the deflection in the bores is so minimal its barely noticeable on a bore gauge. Less than an eigth of a thou. However if you have got access to one its a nice icing on the cake so to say.
        UrS6 Stroker + HTA3586 =
        • Nuvo
          • Nov 2003
          • 3825
          This clip gives a nice explanation.
          clicky
          • s4boy
            • Dec 2010
            • 103
            Rwd19t and nuvo cheer it now make sense".........mark
