Can someone explain in simple words why is it that we say that if the wastegate's membrane gets torn, the boost creeps at a high level?
I was thinking... If i have a tear on the membrane, then the bottom and top chamber are equalised, but the top chamber vents to atmosphere, and therefore any attempt from the N75 valve to pressurise the system is failing...? Hence, i should only be seeing spring pressure in that case?
what am i thinking wrong?
