Any differences between them? Part no's different?
3b block vs aby
Tags: None
dont think there are any big differece in this blocks.. all the parts around ( oilpump etc) from other audi engine will fit... the diesel 2,4 or 2,5 have LOT of more beaf around..!Comment
3b block have idler on oil pump and ABY have separate idler on tensioner .
my opinion is that ABY is much better than 3B.
you can make combination of 3B oil pump on ABY block , but not reverse.
than you must change timming belt (147 vs 151 tetth).Comment
Hmmm...so anyone know if I can I use an ABY water pump, tensioner and belt on my 3B block?
IIRC from Carlos' thread you can't use that setup on the 7A block due to there not being enough material to tap into to mount the tensioner?Panthero Coupé quattro 20vt
Imola B6 S4 AvantComment
I thought there was no difference between the two apart from the 3 bolt holes for the ABY tensioner. But it was pointed out to me that those holes indeed have extra meat inside the water jacket. I've checked my own blocks since to confirm that's the only difference.SSComment
