Engine oil seals
This is a sticky topic.
  • AndyP
    • 6049
    Engine oil seals
    Anybody not wanting to buy oil seals from Audi, here are some sizes so you can try alternative sources:-
    Camshaft seal : 32x47x10mm
    Front crankshaft seal, in the oil pump : 35x48x10mm
    Rear crankshaft seal : 85x105x12mm
    All are double lip seals
    Rear Diff
    Drivers side / small seal : 60x45x8mm
    Passenger side / Large seal : http://www.mister-auto.co.uk/en/shaf...01020537B.html
    sticky made
    • Jeltuh
      • Oct 2007
      • 73
      For the Dutch people. Eriks.nl has some good stuff
      • caterpillar
        • 2480
        Thanks .....!!!
          Nice one Andy
          Any recommendations of good quality brands? Reinz or Goetze etc?
            Just been having a look at the double lip seals and there is quite a choice on these too. http://www.marcorubber.com/radial_shaft_seal_home.htm
            Where did you source yours from?
              This looks like one for rear crank http://simplybearings.co.uk/shop/pro...ducts_id=27762
              • willg54
                • Jun 2009
                • 2055
                ARAI make good lip seals
                1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
                1994 Audi 80 - 2.0 8v (slow but reliable!)
                • AndyP
                  • 6049
                  I get mine from here
                  Unfortunatley you they don't have an online shop, I just tell them what I want and what it's for.
                  • europeanme
                    • Oct 2005
                    • 3817
                    are they near you?....
