Boost leak test results q&a
  • 20Vcqdriver
    • 829
    Ok did a boost leak test on the Cq yeterday and first try the oil dipstick flew out, secured and 2nd attempt I could hear a small amount of air escaping down the exhaust that I assume is where the air is passing the rings and escaping through the open exhaust valves, other than this no other signs of air escaping and it took almost 2 minutes before the air pressure had dropped from 2 to 1 bar
    Is this an acceptable result or should I speed up the build of this spare block I'm working on?
    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
    2004 A4 2.5TDi convertible, re-mapped to 180bhp
    2011 A5 sportback 3TDi-Backbox delete, remap
    Dis you block of the pcv system before pressure testing?
    • prj
      • Mar 2010
      • 6308
      Probably not... block it off at the front.
      Also block the hose going to the lower chamber of the wastegate while leak testing.
      • 20Vcqdriver
        • 829
        Only blocked the one that goes to the MAF to Turbo hose. Why do you need to block wastegate hose as should diaphram be perished, leak test to this too would show it up.
        • prj
          • Mar 2010
          • 6308
          WG will always leak into exhaust.
          Diagram should be checked by visual inspection.
          • Rusty
            • 18953
            Results sound pretty decent to me. If you had 2 bar in there and those were the only leaks, then you're lauging. Good idea to test the DV by blocking it up too; hadn't done that before.
            • Fat Audi 80
              • 10547
              Yep, when S2Driver's car had a boost leak the air was coming out as fast the compressor could put it in!
              The Perfectionist
              • prj
                • Mar 2010
                • 6308
                Per description everything is alright indeed.
                • Rusty
                  • 18953
                  I need to get something that can give 2 bar of pressure into the system... a hand / foot pump just won't get enough air in
                  • 20Vcqdriver
                    • 829
                    I used a spare tyre inflated to 50psi that dropped to 30 (on boost gauge) once attached to the engine via an adapter I made..
                    • prj
                      • Mar 2010
                      • 6308
                      That's pretty clever.
                      • SteveH
                        • 4460
                        I have a compressor and leak testing bung. Call round if you want to use it.
                        91 Modded 3B
                        14 A6 Avant Black Edition
                        • s2driveruk
                          • 12696
                          yes, how my car ever made any boost on the RR day is beyond me with the trail of leaks...ended up being WGFV split, crack in the IM and a split in the plastic elbow pipe going into the MAF-Turbo hose.
                          1992 3b S2 Coupe
                          • driftin jo
                            • Sep 2007
                            • 2222
                            That's what I use as well, I have a pressure bleeder for pressurising the brake fluid reservoir and I use the adaptor hose from this which connects to a valve on a spare tire.
                            It's the same thing as you have on a foot pump so you could use the hose from one of those also.
                            • Rusty
                              • 18953
                              Cheers Steve, I'll take you up on that Got a bung kit but not enough puff Need to test to 1.8 bar at least :mischeif:
