I am looking at changing the map sensor on my AEL to a 3bar item. From what I can see the standard map sensor is a 3pin plug. The 3 bar map sensor is a vag part but is 4 pin. Is there anything I can do regarding wiring to get it to work?
Any help would be great.
Audi A6 AEL 5cyl Quattro breaking.
Audi A5 3.0tdi Quattro Stage 2
07947385043
And you want to increase requested boost 1.2 times across the range?
I hope you are getting a custom map to go with that...
As for sensor - MPXH6300A should work. No idea whether that 4 pin is compatible, because different sensors have different voltage curves, operating ranges and offsets.
