Golf gti audi tt afterrun pump
  • Audi500HP
    • Apr 2004
    • 85
    • Country: Chile
    Hi guys
    Have someone tried the golf GTI afterrun electric pump to replace the original Bosch 0392 029 054?
    The new pump could be better
    the part number:
    OEM number: 078 965 561
    Bosch: 0392 020 039
    Looks similar and its 25 euros cheaper.
    Fernando
    Audi S2 94 6 speed ABY-ADU 330hp, Lancia delta EVO2 mint
    Dr.Ferdinand
    Looks like a slightly better design too
    • jade
      • Jan 2005
      • 1811
      I have had 2 fail, tops have poped off, these look better
      RS 2 580HP
        You might have to modify the electrical plug to get that to work for your 20vT I-5 application.
        • Audi500HP
          • Apr 2004
          • 85
          • Country: Chile
          connector looks similar
          Dr.Ferdinand
            Agree but similar does not mean equal. You might have to trim some plastic to make it fix.
              Looks like you may a guinea pig to give it a try
              • Audi500HP
                • Apr 2004
                • 85
                • Country: Chile
                Im trying to find a second hand pump just to check it, cause its a pretty common item in audi 1.8 5 valves turbo, 2.7 twin turbo.
                If not, Ill buy a new one.. The original cracked the plastic area, doesnt have screws to open it, then the shaft was block..... total mess, unacceptable from a car with 100k and all the services done.
                Fernando
                Dr.Ferdinand
