Coolant leak!!!
  • Rikki Kitto
    • Feb 2010
    • 6276
    Coolant leak!!!
    OK got a coolant leak from the look of it I think it is the head Is it possible for the head gasket to leak coolant to the outside of the block and not into the engine?
  • Rusty
    • 18953
    Turbo feed pipe, under the PAS pump?
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      Leaks from the turbo feed hose, return hose, or rear block adapter are not uncommon.
      SS
      • Rikki Kitto
        • Feb 2010
        • 6276
        Cheers guys will check it out
