Cylinder Head feed identifications
    Can anyone help my identify which holes on the block are the oil feed (s) to the head and which one are the returns from the head?
  • terrybullwon
    • Mar 2006
    • 8782
    With out looking at my spare block I would guess the smaller ones to be a pressure feed and the larger to be a return
    Chef
      Which small ones? as aren't the very small ones coolant?
        Gimme 5 i'll go and look
          yup 5 large returns to the sump.
          Edit: crap description. Deck cooling pics help to show it best:
            Cheers Error
            • Acidburn
              • 13459
              I recognise that engine - I should ask for copyright....
                what are the marks on the pistons dude? looks like mouse 5hite
                maybe from those ones that lived in your boot.. or was it squirrels?
                • Acidburn
                  • 13459
                  Something was ingested by the engine when it was in the s2cab, it marked this and a little on the head but nothing to worry about.
                    ****! I guess you just dressed them back a bit so you won't get hotspots
                    • G60Rallye
                      • Dec 2006
                      • 1321
                      I am 99% sure that the oil feed is the hole behind the 3 headstud from the right. Its the one that lines up with the oil pressure switches.
                      • driftin jo
                        • Sep 2007
                        • 2222
                          Oil Pressure Sender, Switches and Check Valves
                          Perhaps more importantly, it would also line up with the check valve that lives in the block, behind the pressure sender on an UrS4 or ABY or ADU, or on its own for an UrS6, as documented here:
                          Oil Pressure Sender, Switches and Check Valves:
                          • JP
                            • 1858
                            Top Headstuds from left to right
                            2 - oil return
                            3 - oil return
                            4 - oil pressure feed (little one in line with pressure sensors like everyone says)
                            Bottom Headstuds from left to right
                            1,4,6 big holes oil returns
                            All the other little holes around the cylinder are waterways
                            hth
                            UrS6 Stroker + HTA3586 =
                              2 - oil return
                              3 - oil return
                              1,4,6 big holes oil returns.
                              All the other little holes around the cylinder are waterways hth
                              Just to complete the picture, what is the big hole behind the 5th stud from the left on the top row?
