fuel pump location
  • johnsmart
    • Jan 2011
    • 19
    fuel pump location
    where is the fuel pump located on my 93 3b s2 coupe,i think my fuel pump has gone,where is the best place to buy one and does anyone know the part number,any help will be appreciated.regards john
  • S2TORNADO
    • Jan 2008
    • 620
    in the carrier inside the fuel tank.
    • Kieron20V
      • Mar 2008
      • 1505
      Its Inside the tank, under the cover and carpet in the boot.
      New one from bosch dealer, or audi.
      Good used one from a breaker, try "spink" on here, bet hes got loads.
      Have you tested the fuel pump relay first?
      1994 URS4 Avant RS2+
      • johnsmart
        • Jan 2011
        • 19
        fuel pump relay
        what number is the fuel pump relay and where is it located and how do you test it
        • Kieron20V
          • Mar 2008
          • 1505
          Its in the main fuse box under the windscreen, drivers side. Cant remember number but its grey and has a space for a fuse in the top, if you stick a 10A fuse in there i think the fuel pump should run with the ignition on.
          Will confirm in a min.
          • Kieron20V
            • Mar 2008
            • 1505
            have a read of this, lots of things to check.
            • Biggss2
              • Sep 2011
              • 544
              loosen one of the fuel lines touch the contacts together on the relay, fuel should p!ss out, meaning the pump is sending fuel through! away from any naked flames obviously.
              ''I'm 999 thou' short of a mill!''
              • K Simmonds
                • Dec 2007
                • 7627
                The fuel pump relay is in the centre of the bottom row in the main fuse-bow, it's Grey in colour numbered 208. The 3B one does NOT have the slot for a fuse, pretty sure that's only on K jet cars.
                I've got a few good spare pumps, if your after a cheap fix drop me a PM.
                1990 B3 2.0 80 quattro.
                1992 C4 2.8 Avant quattro
                1994 MTM RS2.
                1998 B5 TDI quattro Sport.
                2000 B5 TQS.
