Smokin!!
  • Sir Digby 42
    • Apr 2011
    • 35
    Smokin!!
    The S2 has always been a tad smokey on start up however recently I have noticed that it smokes even when warm...
    Ive also noticed that it uses a fair bit o oil. When I did the cambelt there was a small leak from the crank oil seal but nowhere near enough to warrant the amount of oil used. I also recently replaced the plugs (which were loose) and found that the old ones were covered in oil.
    With the new plugs all in it smokes less but it hasnt completely stopped
    Any ideas on the possible problem?
  • pixsaudisex2
    • Sep 2004
    • 3110
    Clean all the metal pipe out that goes around the engine the breather system gets rather mucky. Few people take the fire trap out probably not the best idea but ensures it breathes well..lol. ( like a wire wool in the pipe.)
    • prj
      • Mar 2010
      • 6308
      Turbo or valve seals.
