Misfire, then non-starter this morning -- HELP!
  • Bowlerwell
    • Sep 2005
    • 1052
    Having cleaned the ISV yesterday to sort out the lumpy idle, I started her up this morning and had very rough running.
    VAG-COM gave a lambda error (possibly because of the misfire).
    Using the 'unplug the injector' method, I discovered that the misfire was on Cyl 2 and 4! (do they even share the same POS?)
    The cables aren't long enough to swap POSs between cylinders, and I don't have a spare any more .
    I took the coilcover off to check the sparkplug boots and spark plugs: no oily mess, plugs are tight, boots look fine. But just incase, I swapped boots 1&2, and 3&4.
    Then the car wouldn't start at all!
    VAG-COM now gives:
    001250 Injector Cyl 2 - Open or short to ground
    001251 Injector Cyl 3 - Open or short to ground
    001252 Injector Cyl 4 - Open or short to ground
    000515 Open or short to B+
    I checked Fuse 28 and it's fine.
    Further VAG-COM readings (after cranking) only give the 000515 Hall sender error.
    I'm kinda suspicious of the hall sender error because it has never been a problem, and the car started a few times this morning (albeit with a misfire).
    The injector errors explain the misfire, but only cyls 2&4 were misfiring first thing!
    I'm struggling here to figure out actually what is wrong.
    Please help!
    JohnB
    John Bowlerwell
    Electronic Engineer
    Present:
    Nogaro Blue RS2 - TOE
    Previous:
    Kingfisher Blue S2 - UAA
    Volcano Black RS2 LHD - DEX
  • sjw185
    • 1175
    Hello John,
    Are the injector codes not from you unplugging them checking for missfire?
    Your right with the Pos think one does 1,2,3 the other 4,5
    You could try that trick of running water over the cam sensor?
    Hows your fuel pump/relay?
    After market alarm?
    Disturbed any wiring on the bulkhead connectors when working with ISV?
    cheers
    Steve
    • johne
      • Apr 2007
      • 1405
      Given that the ISV is close to the POS's, I'd check that you haven't disturbed any of the connectors around there.
      John
      • Bowlerwell
        • Sep 2005
        • 1052
        Thanks Steve, You're right, the injector errors will be from me unplugging them. Good call!!
        I might try that water trick (but it won't explain the misfire...).
        I may well have disturbed something on the bulkhead when doing the ISV... I'm not sure what would cause a misfire, then non-start...
        John Bowlerwell
        Electronic Engineer
        Present:
        Previous:
        • Bowlerwell
          • Sep 2005
          • 1052
          Note: After re-fitting the ISV yesterday, the car did start and run fine. (although i didn't frive anywhere)
          John Bowlerwell
          Electronic Engineer
          Present:
          Previous:
          • sjw185
            • 1175
            When did you start getting missfire trouble?
            Mine had a lumpy idle and turned out to be a dodgy injector after much plug, coil and pos changing
            I tracked mine down by swapping coils and going for a blast and pulling plugs straight away to check colour.
            Ended up changing injectors until the black plug changed cylinders.
            You need it running first though
            • Bowlerwell
              • Sep 2005
              • 1052
              Misfire started this morning Steve. Car started and idled fine after ISV was put back in yesterday.
              Non-start happened after I swaped coil pack boots between cylinders...
              John Bowlerwell
              Electronic Engineer
              Present:
              Previous:
              • johne
                • Apr 2007
                • 1405
                John, how long did you let the engine run for yesterday? If you didn't let it warm up fully and didn't drive it then all you've got is a fouled spark plug - happens with mine everytime if I just do something like start, drive out the garage and stop, only to resatart later.
                I have the confidence to carry on driving and it'll clear as I get down the road but you might want to pull your plugs first and clean them.
                John
                • Bowlerwell
                  • Sep 2005
                  • 1052
                  Thanks John.
                  I'll take the plugs out and clean them.
                  I still have the cam sensor error... maybe it's just coincidence that it's gone? Does it connect on the bulkhead too? I might have knocked it when fiddling with the POS connectors this morning.
                  John Bowlerwell
                  Electronic Engineer
                  Present:
                  Previous:
                  • johne
                    • Apr 2007
                    • 1405
                    Cam sensor connects at the bulkhead along with the knock sensors etc. It would be some coincidence if it happened to fail at exactly the same time.
                    John
                    • Bowlerwell
                      • Sep 2005
                      • 1052
                      Thanks John!!
                      I'll clean the spark plugs, change the boots, and check all the bulkhead connections after lunch.
                      JohnB
                      John Bowlerwell
                      Electronic Engineer
                      Present:
                      Previous:
                      • Bowlerwell
                        • Sep 2005
                        • 1052
                        I have cleaned the spark plugs, and changed the boots back to the previous order.
                        I also had a fiddle with the connections on the bulkhead (although i'm not sure which one is the hall sensor).
                        Now it still doesn't start, but i get no errors on vag-com. not even 00513 engine speed.
                        I do, however, now get an autocheck warning for oil after cracking...
                        Any ideas?
                        John Bowlerwell
                        Electronic Engineer
                        Present:
                        Previous:
                        • Tonks4x4
                          • Nov 2005
                          • 3062
                          The connector for the haul sender is the plug at the front of your engine that is fixed to a small bracket on your inlet manifold.
                          If you remove the coil pack and your plugs, put your plugs into the coil boots and then crank it over you will see if they are all sparking correctly.
                          Audi Nut!!!
                          • prj
                            • Mar 2010
                            • 6308
                            1. Clear all codes with VAG-COM
                            2. Crank for 20 seconds, see if you get any codes.
                            If you don't, make sure you have fuel and that the fuel pump is activated during cranking.
                            You can try taking the fuel rail off, aiming it away from the car and seeing if the injectors are spraying fuel.
                            EDIT:
                            Yeah, and check for spark as well, as noted above.
                            • Bowlerwell
                              • Sep 2005
                              • 1052
                              Thanks for the tips chaps. Much appreciated. I probably don't have any more time today to lookat this
                              Dimitri, will the injectors just pull off (with the fuel rail) or are they fixed down?
                              Thanks.
                              John Bowlerwell
                              Electronic Engineer
                              Present:
                              Previous:
