Hi guys need advice twice now in the last two weeks when iv started the car it starts and straight away cuts out it does this about four or five times then starts and runs ok any feedback .
You should pull codes for clarity. My cabriolet did the same and the reason was the immobilizer that cut out the engine (also had code from it). Cured with another key, (the main fault may be in the ingnition switch that read the immo chip, but changing the key also helped) so wort trying out if you have a spare key.
S2 Avant SleeperWagon 570hv and 765nm on 2,2bar/E85
