very hot exhaust
  • miljan
    • Dec 2008
    • 49
    • Country: Bosnia and Herzegovina
    very hot exhaust
    in my car engine is new. I just mount it in the car. the engine running at idle, and the turbine exhaust is very hot. there are completely red. why?
    http://akcrankshaft.com/forum/showth...tid=129&page=1
  • Nuno Cristiano
    • Aug 2010
    • 421
    • Country: Portugal
    What AFR and Timing you use? EGT very high...
    .: MINI Cooper D 08' :.
    .: Audi Coupe Quattro 20V 91' :.
    .: Audi Porsche RS2 95' :.
    • 220bhp
      • 2578
      • Home: United Kingdom
      I had this issue a few years ago,it turned out to be the TPS.Changed it for a used one includeing the hole throttle body,fixed my problem,but there are other things that can cause this such as the things that cause lean mixture,such as poor fuel supply,pump,fuel filter,blocked cats,etc.
      you need to start by checking these things one by one,start with the TPS,there is alot of info one hear,do a search
      • mcandmar
        • Apr 2004
        • 5118
        I'm amazed it can get that hot at idle, never seen a downpipe that hot. Is the engine standard or have you changed chips or injectors?
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • Billman
          • 4129
          what engine is it? 3B or ABY?
          Go Holset or Go RS4
          • miljan
            • Dec 2008
            • 49
            engine is 3b with small modifications. before the overhaul, he was perfectly correct. I'm sure something did not install well. I do not know what?
            • Jeltuh
              • Oct 2007
              • 73
              To much fuel or spark timing to late, can be anything from, lambda to MAF, ECU.
              • spink
                • 4382
                out of interest,is the engine in this?
                • Thuppu
                  • 4115
                  Is it possible to get the distributor wrong in 3b, so the timing is out..?
                  • Audi_CQ
                    • 940
                    • Country: Norway
                    Bad cam timing? (Exhaust opening too early)
                      Cam and Crank Timing Marks
                      I think you *might* have the answer there.
                      Here is some cam (and crank) timing info:
                      • miljan
                        • Dec 2008
                        • 49
                        Last night I checked the cables and spark plugs. All are correct. timing is OK. motor works great. exhaust turns red when the transmission in neutral, and I keep in throttle 3000 rpm more than 1 minute. We apologize for not immediately explained. This is because of my poor English.
                        Could that be because 7A exhaust cam?
                        • Billman
                          • 4129
                          maybe it cant adjust the lambda good enough at this RPM/load site. Maybe you map is wrong....
                          Go Holset or Go RS4
                          • Nuno Cristiano
                            • Aug 2010
                            • 421
                            • Country: Portugal
                            You use StandAlone ECU?
                            • miljan
                              • Dec 2008
                              • 49
                              I use the original 3b ecu.
