GT3076R vs GTX3071R
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    GT3076R vs GTX3071R
    I had a look into the atp website today and noticed 2 things.
    1) the GTX series compressor wheels are now available to upgrade at a reasonable price
    2) the 3071 has pretty much identical map as the GT3076. Some say that it could also spool a bit better and have less lag... But still produce more than 500hp
    Finally, what is this GTX3576? Is it a 3076 compressor wheel with a GT35 turbine wheel? That with a .63ar would possibly produce less backpressure than the 3076...
    Discuss...
    sent using Android
  • djh
    • Jun 2011
    • 1622
    lol I asked on the forum about comments people made about the gtx3076r and only one decent forum member responded.
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      Well as far as I can speculate, the GTX3076 would spool as the GT and produce more power, but according to a site that they tried those in subarus the difference was 25hp at similar boost (1.9bar)
      sent using Android
      • prj
        • Mar 2010
        • 6308
        The idea is to run more boost, not the same boost...
          How many indecent forum members responded?
          (Where:
          indecent [ɪnˈdiːsənt]
          adj
          1. offensive to standards of decency, esp in sexual matters
          2. unseemly or improper (esp in the phrase indecent haste)
          indecently adv )
          • Nik0las
            • 1345
            • Country: Bulgaria
            GTX3076r vrs GT3076r
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              that is the first time a GTX has different spool rather than hp difference!
              • AndyP
                • 6049
                $300 for the upgrade kit, that's really tempting!
                edit : Just re-read that, and it's only $300 if you buy a new turbo
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  oops, missed that, but i wonder if owen can do any such upgrade if they have access to the wheels.
                    There is no such upgrade in reality as the gtx wheels can't be bought separately through normally sources according to Owens
                    The upgrade for gt turbos is the hta or turbo dynamics billet wheel
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      do any european shops do the HTA upgrade?
                      • diesel des
                        • 3896
                        The gtx wheels can be got. Not many at the moment but give it time. I'm yet to see a comp map for a hta so they can't be compared on paper. I would go for the gtx 3071 over the gt3076. Similar power, less lag due to the reduced inertia of the smaller exducer on the comp wheel.
                        The gtx3076 is a larger compressor than the gt3076 and not supriseingly flows more. Fractionally more lag too. Maybe even 600hp when on the gt35 turbine as in the gtx3576. The gt30 turbine was always said to be slightly undersized for the 76mm compressor, but it works well enough. The 71mm compressor is a better match.
                        • A80Avant
                          • Sep 2005
                          • 10873
                          • Country: Greece
                          I know a few people that use hta in 4 cyl. 1.8T engines with good results. Forced Performance say it flows 57lbs which is sort of as the GTX3071.
                          Trouble is that the 3076 as you say has the turbine as it's weak point, causing high back pressure. However I'm not sure what's going to happen to the lag...
                          sent using Android
                          • diesel des
                            • 3896
                            Why don't hta show maps for their compressors. Without them your just ******* in the wind.
                            • A80Avant
                              • Sep 2005
                              • 10873
                              • Country: Greece
                              at least they posted the 57lbs! Comp are much worse than that!!
