Anyone have tested Injectors Dynamics ( ID725 ) in yours cars?
I´m reading about it, Bosch, Siemens and Delphi.
Regards
I run Injector Dynamics 2000cc injectors in Da Monstah. This car pulled 755hp at the wheels running 36 lbs of boost and E85 for fuel. That's why I needed such a large injector to handle the extra fuel from the 755hp and E85. They also let the car idle at 1000 RPM or so but that's more based on the lumpy cams that I run rather than the injector not being able to handle the smaller fuel spray for lower idle RPMs. I LIKE THEM A LOT.
Hap, wit dakine dale talk not from Evahboost, Maguire
You do know there just a standard Bosch injector and you dont have to pay there mark up
If you buy EV14's from Five O Motorsport they come as a flow matched set, you get a report detailing flow from each injector at different pressures, and each injector is hand maked so you know exactly which is which on the report.
ah! but there is a difference in dynamic and static matching. Mine were static matched, and bought from injector clinic, but apparently dynamic matching is better.
ID are a scam, they are BOSCH natural gas (only) injector match flowed sold as a fuel injector. Sooner or later it will be a lawsuit Mr B against ID, every bosch injector ID resells comes with big red warning NG use only. And if you will melt your engine due to one of those or all going lean for split sec ID will not talk to ya
Where to buy EV14 2000cc's from this side of the pond? Have only found a single dedicated shop in Finland.
I've heard the filter screens cannot be removed on EV14's, can someone confirm?
