Very poor oil pressure
  • Rikki Kitto
    • Feb 2010
    • 6276
    I know this has been covered a lot so sorry in advance, Used to have 2bar on idle 5bar under load. Now it is dropping as low as 0.5 on idle but still giving 5 under load. Seems to have a problem building pressure when first started too.
    Any ideas?
  • willg54
    • Jun 2009
    • 2055
    oil level dropping at all?
    1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
    1994 Audi 80 - 2.0 8v (slow but reliable!)
    • DJones
      • Jun 2005
      • 2020
      Possible blocked pick up mesh/strainer...
      • mcandmar
        • Apr 2004
        • 5118
        First thing i would do is swap out the pressure sender, the reading slowly drops before they die.
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • 220bhp
          • 2578
          • Home: United Kingdom
          As above,I had this on my new build,very worrying with a new sender. checked it with a gauge, and the oil pressure was first class.Changed the sender and the oil pressure is spot on.
          • caterpillar
            • 2480
            put a new oilFILTER on, it may have a leak inside.. the org audi filter,please
            • Rikki Kitto
              • Feb 2010
              • 6276
              Cheers for the help guys, it had a new sender not long back, does have slight oil leak nothing too dramatic, Will get the pressure checked out with a proper gauge change oil and put original Audi filter on fingers crossed.
              • willg54
                • Jun 2009
                • 2055
                Well if the oil isn't disappearing, that's a good sign. Like people say, could be sender or also maybe a lazy getting pump but I think its rare they go.
                Sent from my HTC Desire using Tapatalk
