VGT Turbo Applicatiom ?!?
  • ian4455
    • Nov 2010
    • 787
    Interesting, wonder if anyone will be installing one of these on a 20V ?
    http://www.dsmtuners.com/forums/turb...r-project.html
    Billman's done this already AFAIK
      is the vane control mapped?
      • quattro84
        • Mar 2006
        • 947
        Billman didn't control the actuator though.
        I work with these on a daily basis. CTT (Holset) rules when it comes to VGT mechanism.
        Garrett doesn't even try anymore to make it work for heavy/light duty vehicles. They simply can't figure it out
        Biggest downside is the weight. The HE431 for instance has the HX40 turbine rotor size, but due to the entire mechanism weighs up to 25kg's
        Upside: You can make boost at any operating point, control turbine pressure & temp by simply moving the slots.
        It has been developed / made durable for diesel exhaust temps ~800deg max/700 continuous. Don't see this getting usable for Otto unless you run alcohol based types of fuel.
        • ian4455
          • Nov 2010
          • 787
          Found it interesting that a new stepper motor had been fitted with programmable control board in replace of the Holset unit via the link above. Would be good to have boost lower down the rev range through to top end..
            I thought the 997 TT used VGTs from Borg Warner?
            • andy10v
              • 5996
              Derek has one fitted to his 20vt4kq
              well folks.... after my episode with the 86 zermatt car from NC with the paint issues and whatnot, and then my issue with not being able to stop for blazers in front of me, i decided to console myself with buying the car i originally wanted before going to NC.... a very clean, very nice 4kq, a...
              There is a dyno graph showing when it opens in his thread as well.
              Sold ABY-stock
              • quattro84
                • Mar 2006
                • 947
                Would be even better to combine it with the TT-RS FSI engine.
                With the current IL5 design you lack the VE to properly fill the engine down low. With the VGT you can actually 'make' your VE by stuffing it with fresh air.
                Combined with the FSI direct injection you could actually make use of that excess of air, and control the combustion energy (heat release) and thereby turbine energy better.
                Biggest problem: Surge. Let alone under heavy throttling.. don't even want to think about transient respons...
                Man i need 50k and a 2 year sabbatical...
                • quattro84
                  • Mar 2006
                  • 947
                  Yes, Porsche uses VNT (rotating vanes) and tried VFT (twin scroll with flap)
                  I don't think they made a lot of money on those models after all those recalls...
                  BMW is still using it. But is not as controllable compared to sliding nozzle design by CTT.
                  I think the stealer charges about €3500 for a spare one.
                  • ian4455
                    • Nov 2010
                    • 787
                    ...Simple and works, good idea for moving the mechanism.
                    • bikerjim
                      • Feb 2008
                      • 1028
                      That is correct, think some BMW models do too.
                      • quattro84
                        • Mar 2006
                        • 947
                        BorgWarner isn't ready yet:
                        BorgWarner Turbo Systems currently offers turbochargers with variable turbine geometries for exhaust temperatures up to 850°C. In the future there will be turbochargers with VTGs for diesel engines with exhaust temperatures up to 900°C.
                        Refinement of the VTG technology for use at even higher exhaust temperatures will expand the possible range of applications to include gasoline engines.
                        And if 'ze germans' don't declare it ready yet, it isn't ready yet
                        • Billman
                          • 4129
                          I used 2 actuators, one for opening the vane during off boost to keep the engine cool and one during boost to hold the vane shut during spool up and open when above certain pressure. The mapping part would be the easy part with it since with vems I can use a second n75 to control the actuator. (see picture).
                          The was only one downside that had me remove the HE351VE:
                          It was massive for the b4 platform with the Mtm exhaust manifold.
                          The is a control unit the dodge guys use that controls the stock holset stepper motor but I don't think it's necessary on gas (+there was no room for it).
                          Go Holset or Go RS4
                          • djh
                            • Jun 2011
                            • 1622
                            • Home: United States Current: United Kingdom
                            what did it drive like with that on?
                            • ian4455
                              • Nov 2010
                              • 787
                              So why did you remove it ?
