parts from S2 to 7A
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    parts from S2 to 7A
    can i apply intake manifold,exhaust turbo manifold or use OBX s2 manifold,oil adapter from S2 to 7A egine?I want to turbocharged my 7a and i want to save much money for this parts as i could. What u think?Any experience?
    i want to ran a oem pistons and rods,but of course with very friendly tune.Head i want to send to shop and change crankshaft and rods bearings for a new one
    Audi Coupe Quattro 2.3 20V
  • Nuno Cristiano
    • Aug 2010
    • 421
    • Country: Portugal
    Hi Tom,
    Actually a friend have rebuild original 7A to turbo. He have 034 Injectors ( 30lb/min @ 3bar ), Intake Manifold 3B, EM 034 Motosport, turbo T3/T4, VEMS ECU.. no more.
    Actually he waiting by Fuel Rail 3B.
    .: MINI Cooper D 08' :.
    .: Audi Coupe Quattro 20V 91' :.
    .: Audi Porsche RS2 95' :.
    • shone190
      • Oct 2006
      • 527
      • Country: Serbia
      I have 7A block, pistons and rods with other 3B parts and everything works fine for about 3 years
      Audi URquattro 4.2l, Dodge Charger 7.3l, Golf 4 TDI 4Motion
      • Tom_
        • Oct 2007
        • 1301
        Nuno Cristiano : so 3B intake manifold fits to 7A head?Its good to hear that. I use a WOLF EMS ecu but i want a buy exhaust manifold,maybe a used a OBX turbo manifold and change a head flange. More info about your friends car?
        shone190 : but u have a 3b head?
        • shone190
          • Oct 2006
          • 527
          • Country: Serbia
          Yes, I have 3B head, I mean that 7A rods and pistons are OK for standard turbo setup
          • Nuno Cristiano
            • Aug 2010
            • 421
            • Country: Portugal
            He use 3B Manifold without problem but not use water manifold 3B, use original of 7A. To use water manifold in 7A head you need rework head. In my Quattro i make it
            Need open adicional 3 or 4 holes ( if a remember well ).
            • Tom_
              • Oct 2007
              • 1301
              shone190 : i think too,with a good tune and average boost,i thought it will be no problem.
              Nuno Cristiano : have any pictures or informations about the adittional holes for water manifold?I cant imagine that where they belongs.
              • Nuno Cristiano
                • Aug 2010
                • 421
                • Country: Portugal
                See my project and you see my modification
                Good luck your 7A TURBO!
                • Tom_
                  • Oct 2007
                  • 1301
                  but when i use a 3b im,its not necessary to drill the holes for water manifold,isnt it?I think that i use a 3b im and obx turbo headers but i custom the flange,because it doesnt fit.Then i do a ic,use a injectors,change main bearings,rod bearings.Use a piggyback (ecu) and start and tune,this do a person what knew what he did.What u think guys?Any comments?I will be a very glad if You help me this way to collect the parts,which be fit and be ok.
                  • Tom_
                    • Oct 2007
                    • 1301
                    anyone know?
                    • Mcstiff
                      • Oct 2004
                      • 504
                      A possible issue with a 3b intake on a 7a head is the 7a water manifold. It is a tight squeeze but you should be able to sort out a universal coolant hose.
                      I'm putting a manifold built by Hank Iroz on my 7a so the 3b may have more clearance...
                      1995 1PissedOff90sigpic1991 USDM CQ 7aT
                      • Tom_
                        • Oct 2007
                        • 1301
                        Mcstiff : nice,how much payed for it?It looks good and do you fits that im without problems?
                        i´ve already find it, 750 usd
                        or use a AAN intake manifold,and custom it,for reason of servo pump.Or same problem as a 3B with cooland manifold?
                        • Mcstiff
                          • Oct 2004
                          • 504
                          I should have said that EFI Express sells the intake. It is a tight squeeze but I think everything will fit back together.
                          • Nuno Cristiano
                            • Aug 2010
                            • 421
                            • Country: Portugal
                            AAN intake is good option but you need rotate water cooler ( i think 45º is ok ).
                            In my opinion and to you, low cost project, i use 3B intake Manifold, 3B water manifold with head machined. With 300€ i think you make all.
                            • Mcstiff
                              • Oct 2004
                              • 504
                              Youtube embedding not working http://www.youtube.com/watch?v=_lgiqTzTIRk
                              It would be interesting to test how much the 3b water manifold helps. I am going to stick with the single 7a port for this summer.
                              The 3b intake with 7a port would be the absolute cheapest but I'd keep a close eye on temps.
