Starting a Project 7a Cam Cover Coil Packs or LS2
  • ian4455
    • Nov 2010
    • 787
    Great info and like the 7A cover, coils now sorted out
    • ian4455
      • Nov 2010
      • 787
      Originally posted by eske
      I have 1.8t COPs with 7A cam cover. The COPs just needed some grinding. Didn't modified the cover.
      Who did your loom ?
      • eske
        • May 2010
        • 41
        Originally posted by ian4455
        Who did your loom ?
        I did. It was my first loom ever.
        • ian4455
          • Nov 2010
          • 787
          they do the connectors but doesn't seem to include the rubber boot that seals the loom to the connector housing... any info of the source for parts please ?
          • eske
            • May 2010
            • 41
            Protective cap for 4 pole
            Protective cap for 3 pole
            4 pole connector + pins
            3 pole connector 0.5-1.5mm2 or 1.5-2.5mm2
            • ian4455
              • Nov 2010
              • 787
              Thanks for the info, I'm a little confused ... i know i need qty 4 pole + rubber boots for the coil packs but what are the other 3 pole connectors for ? I've a 3b so might explain why i'm confused, how may of the 3 pole connectors do i need ? Thanks Ian
                Newsh was asking recently about a 3B o coil conversion, as it's a lot more involved than on an ABY style car... You can convert to an ABY ECU or there was a kit used by AndyP. Apologies if you knew this alread, hope this helps if you didn't.
                • eske
                  • May 2010
                  • 41
                  They are for the AAN/ABY/ADU, don't know how to do in 3B.
                  • Nik0las
                    • 1345
                    • Country: Bulgaria
                    #24
                    do you need 7A top cover?
                    • ian4455
                      • Nov 2010
                      • 787
                      Thanks i've already got a 7a top cover, need to consider ecu upgrade to AAN/ABY/ADU or VEMS.
                      • SteveH
                        • 4460
                        Me too, I'm thinking taking the 3B to AAN/ABY will be the cheapest route. Just need to sort the TFSI coils and the loom.
                        91 Modded 3B
                        14 A6 Avant Black Edition
                        • Tom_
                          • Oct 2007
                          • 1301
                          • Country: Czech Republic
                          #27
                          any experience with 7a engine?I want to remove old distributor.I havent any experience with this things
                          Audi Coupe Quattro 2.3 20V
                          • G60Rallye
                            • Dec 2006
                            • 1321
                            You have to remove the rubber boots from them. Then the holes need drilling to 28mm, and the ridges need milling to get them to sit down properly onto the plug. Once thats done they fit like a dream. I have kept the alloy plate to mount them up onto the laithe so if anybody wants one doing its not too much work.
                              Nice
                              • ian4455
                                • Nov 2010
                                • 787
                                [QUOTE=G60Rallye;619397]You have to remove the rubber boots from them. Then the holes need drilling to 28mm, and the ridges need milling to get them to sit down properly onto the plug. Once thats done they fit like a dream. I have kept the alloy plate to mount them up onto the laithe so if anybody wants one doing its not too much work.
                                Looks great, like the finish ! What paint is it thats been used on the cover ?
