Head Gasket in 7A
  • Nuno Cristiano
    • Aug 2010
    • 421
    • Country: Portugal
    Head Gasket in 7A
    Hi friends,
    I have a small question to do.
    I´m rebuild my 7A engine, use 82.5mm of bore.
    My pistons have ( JE ), in top, 81.5mm. I can use to head gasket bore of 82mm or is danger because my crearence is only of 0.5mm?
    Regards
    .: MINI Cooper D 08' :.
    .: Audi Coupe Quattro 20V 91' :.
    .: Audi Porsche RS2 95' :.
  • fasterthenrs2
    • Nov 2007
    • 275
    • Home: Latvia Current: United States
    you have a few issues there 7A is 82.5 bore, if i understand correctly you r trying to use 81.5 mm pistons that will not work, you can cut your HG to 82.5mm with out problems
    DD 1990 CQT 800+HP SOLD
    1/4 mile 10.70@135.66
    (SOLD)
    http://www.youtube.com/watch?v=Yy-YlssmSfY
    http://www.youtube.com/watch?v=8XgzVJyvrfg
    2003 A6 4.2 Quattro
    97 MB S320 DD
    • Nuno Cristiano
      • Aug 2010
      • 421
      • Country: Portugal
      Probably i´m explain bad
      I have in my engine JE pistons of 82,5mm. In top of piston i have bore of 81.5mm. Bore of cylinder is 82.5mm and bore of RS2 head gasket is 82mm. RS2 gasket have ideal ( to me ) dimension bore x thickness 82mmx1.65mm.
      My question is, is problematic i use bore of gasket of 82mm in my block of 82.5mm?
