I see after re-reading the first post. You want something modern and minimum 55mm compressor inducer and 57-62mm turbine exducer. Start with A/R 0.63 and try a bigger housing if necessary.
This is not "the same spec" but a spec that will give you around 500hp with all the other required supporting mods.
I think Hoffer76 was looking at a 500HP K26/7 hybrid that used a #8 hotside. Would have been laggy, full boost 4500 or so in 3rd (compared to 3800rpm on mine) but stock fitment on an S2 - no custom oil and coolant lines - and half the price of a Garrett.
Personally I wouldn't want any more lag than I have now, but if it was a track / weekend car I could trade a bit more for 500hp... if you want low lag and 500hp+ then you need a stroker or BB turbo :mischeif:
