Turbine impeller machining
  • Billman
    • 4129
    I was looking again at the pictures of James Bufkin and I while I new it is done by many people I never given any thought there.
    What is it with the machining of the turbine impeller nut?
    Does it reduce the weight that much that it is worth?
    Does it make balancing difficult?
    take a look at those pictures and comment please.
    Here as on SQ K27:
    and then machined also
    Go Holset or Go RS4
  • mcandmar
    • Apr 2004
    • 5118
    I think its part of the balancing process..
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • Billman
      • 4129
      No, not in that extent.
      Go Holset or Go RS4
      • AndyP
        • 6049
        The top one, where it's just machined on one edge I would say is balancing. The others that are machined in the middle I would say are for lightening, taken to the extreme!
        • Billman
          • 4129
          Yes the first one is not machined for "enhancement" but for balancing. It is clear. But does anyone has any data as to how much does this kind of machining improve spool up on a mid frame turbo?
          Go Holset or Go RS4
          • quattro84
            • Mar 2006
            • 947
            It's neglectable, inertia equals mass times squared radius, so mass that close to the center of rotation does not contribute that much.
