Piston identification
  • DJones
    replied
    Yes Mr Smith you live and learn....
  • aelred
    replied
    All sorted then Mr Jones
  • DJones
    replied
    Originally posted by djh
    do you know which was the lighter set the aby or 3b?
    The 3b were lighter. From what i have found out they have a target weight when manufacturing and the + or - is a reflection on how far away from that target weight they are..
  • Billman
    replied
    I believe they put in every engine either all + or all -. so the deviation between pistons in one engine is as small as possible (in mass production)
  • djh
    replied
  • DJones
    replied
    Originally posted by JariP
    How big is the weight difference?
    Circa 4 grams each.
  • JariP
    replied
  • DJones
    replied
    I have just weighed them and the + ones are heavier so I'm guessing that's it..
  • DJones
    replied
    I'm wondering if it is to do with balancing/weight of the piston, as they are all the same part number. RR, ADU, AAN ABY & 3B....
  • DJones
    replied
    aby and 3b differences?
    Yes one was an ABY and the other was indeed a 3b but what's the difference? they measure identically with no other obvious identifying factors... I thought they were all same in the turbo engines.
    Thanks - Darren.
  • djh
    replied
    replied
    I'm pretty sure they're graded for final size.
  • DJones
    started a topic Piston identification
    I pulled a couple of old engines apart today, whilest both have the standard size markings on one side i.e. 80.98 one engine set had -05.11 marked on the oposite side and the other engine set had +05.12.
    Does anyone know what these later numbers identify? As my understaning was they either had 80.98 - standard. 81.23 - 1st oversize. 81.48 2nd oversize.
    Both sets were Kolbenschmidt pistons.
    Thanks in advance.
    Darren.
