Piston pin and balancing dilemma!?
  • Thuppu
    • 4115
    Ok, so it's not a disaster? And if I get few grams of the piston and pin the error isn't even that bad...
    • JP
      • 1858
      Max you will safely take of a piston is 3-4grams which is really not worth the effort.
      UrS6 Stroker + HTA3586 =
      • Thuppu
        • 4115
        Ok, thanks JP. I think I can sleep at nights now.
        • Thuppu
          • 4115
          Emailed CP-pistons by this issue, and it seems that they can provide 9310 alloy pinns with thinner wall thickness. The JE HD pins has .210 thickness and these CP's has .160 thickness and only 90 gram weight but still good for 5cyl/700hp. Hmm...
          • Thuppu
            • 4115
            So I did order the CP piston pins. Case hardened and cryo treated 9310 alloy, and they are specsed to 175-200hp/cyl. Should be enough..?
            The pins weight 90 grams, so it's only 6 gram more than my current pins, and 50% of that is only 3 gram. And after I remove all sharp edges of the pistons we are really close to the orginal balancing factor.
