RS2 Cam timing & components
    Dont' forget that your lining up the two cam marks inside as well
    • twoqu
      • Sep 2003
      • 3103
      Also that seems right. The half a tooth difference is down to the one less tooth on the cambelt. Just as the "extra" tooth on the ABY/AAN puts the pulley back to the correct alignment.
      That also suggests the pulley has the same relationship between the keyway and the marking.
      Without doubt being a limited run model, Audi were not going to tool up to make a batch of slightly diferent components. So they have modified or adapted what would have been stock ABY components to do the job.
      I understand the principle of the water pump difference!
      • twoqu
        • Sep 2003
        • 3103
        So are we suggesting that its the cam sprocket on the exhaust that alters the timing of the inlet. That makes more sense.
