cylinder heads
    Originally posted by audinut
    basically wanted to know if a 96 AAN head is the same as a ABY
    See, if you had just asked the real question, you would have got the answer you needed: YES. But hey some people will have learned something else along the way.
    • JP
      • 1858
      Pretty much identical other than the engine code stamp on the back.
      UrS6 Stroker + HTA3586 =
      • porkkis
        • 1994
        Yes it is.
          Not like this?
          • JP
            • 1858
            Originally posted by UrS4boy
            Not like this?
            No that's an ADU, ABY and AAN will be in same location but with ABY and AAN as the beginning of the code
              Duh. I *know* that. But you said of the AAN vs the ABY heads that "Pretty much identical other than the engine code stamp on the back." referring, I thought, to some markings on the ABY head. I am confused? What did you mean? Do you have a photo of said "engine code stamp on the back"?
              The reason I am pushing the point is if there is some new info, I would up date my AAN Engine Numbers: Location and Engine Build Dates post with the new info. See link:
              • JP
                • 1858
                Lol dry English humour pointing out the only difference in the two heads was that one would say ABY and one would say AAN.
                p.s. that's a nice useful link
                • audinut
                  • Jul 2009
                  • 2195
                  Many thanks
                  NOT a car dealer! just an S2/RS2 enthusiast
