engine speed sensor
  • Bullysteeth
    • Jan 2012
    • 830
    engine speed sensor
    wot does it do,
  • rj scotty
    • May 2006
    • 2195
    Have you scanned your car with ignition on but engine not running by any chance?
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
    • Bullysteeth
      • Jan 2012
      • 830
      no it was running when i poped in to see it, and connected to the diag, cleared the fault and it didn't come back, but we'll see when its back in a couple of days, so wot does it do bud
      • rj scotty
        • May 2006
        • 2195
        It tells the ecu that the engine is spinning and at what speed.
        Just be aware that if you scan with the ignition on and engine not running you will always get the speed sensor fault even though there is nothing wrong, its just a quirk with these cars
          G4 crank position and G28 engine speed sender info
          Originally posted by Bullysteeth
          wot does it do,
          Tells the ECU what the engine speed (RPM) is. It does this by counting the teeth on the ring gear (138/rev IIRC) on the flywheel. Important to engine starting and running. More info by clicking on the link and then on the G28 label on the upper right side of the diagram:
          • Bullysteeth
            • Jan 2012
            • 830
            http://members.shaw.ca/speedtek/UrS%...ice%20Map.html
            Top man, reading that it may be filthed up
            • vonbeck
              • 2455
              i think mines filthed up but dont want to take it out in case i break it will get a new one first, do i ask for a G28 speed sensor or has anybody got the part number
                PNs are in the link I posted above.
