Idle adjustment
  • horvathg
    • Dec 2003
    • 556
    Idle adjustment
    Hi,
    Is there a way to adjust iddle speed on ABY? As it be űcame a bit colder in the morning, my iddle raised a bit and it doesn't want to go below 1000. Originally it was just a bit under 900. Anything to do?
    Gabor
    96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
  • horvathg
    • Dec 2003
    • 556
    Originally posted by horvathg
    Hi,
    Iddle adjustment, please guys. I know its a stupid amateur questiion but that I am. PLZ
    Gabor
    • porkkis
      • 1994
      It should stay over 1000 rpm when the weather is cold and the engine hasn't warmed up yet.
      And it's a bit of that kind of a question as there is no such adjustment in our cars. The ECU controls everything.
        Porkkis is right - it is fully controlled by the ECU. It controls idle based on air temperature, water temperature, whether your aircon is running amongst other things.
        You may just have a faulty, dirty or disconnected sensor which is making the ECU do this.
        Of course you may just have a faulty/sticky idle stabiliser valve (ISV) which is the device controlled by the ECU to set the correct position for airflow when idling.
        Pull fault codes first .
        Paul
        • horvathg
          • Dec 2003
          • 556
          Paul
          All right,
          Thank you. I'll go to the service to plug in the VAG tool. Again thank you boys.
          Gabor
          • porkkis
            • 1994
            As I said there is probably nothing to service as the higher idle rpm when cold is completely normal.
            Do it if you can't sleep, I wouldn't bother.
