710 N valve
  • audinut
    • Jul 2009
    • 2195
    710 N valve
    Can you guys hear your 710n work?
    recently i have noticed that i can hear a woosh as if its an aftermarket dump valve , no loss in power or any other symptoms?
    NOT a car dealer! just an S2/RS2 enthusiast
  • Bullysteeth
    • Jan 2012
    • 830
    Yep and wastegate chatter
    • audinut
      • Jul 2009
      • 2195
      hmm the chatter might mean yours is shot mate ? when i fitted my new one it elimitated the chatter , mines literally just a whoosh sound
      • Rusty
        • 18953
        Do you have a stock airbox or another setup?
        • Bullysteeth
          • Jan 2012
          • 830
          mines not that loud, just a background stissssssss, but you maybe right i need to look into my wategate, maybe its the dreaded ghost in MY machine or only a diaphram
          • audinut
            • Jul 2009
            • 2195
            stock everything
            • driftin jo
              • Sep 2007
              • 2222
              Wastegates don't chatter, I think what you are refering to is compressor stall.
              • Bullysteeth
                • Jan 2012
                • 830
                its a fluttering sound, wots compressor stall ?
                ps sorry audinut for jumping your post bud
                • Tony Stark
                  • Nov 2009
                  • 288
                  On our engines what does the 710N do? When? And why?
                  Dont mean to push in, just thought ask while its on topic 'cause i dont know
                  • driftin jo
                    • Sep 2007
                    • 2222
                    When do you get this noise ? When you lift off or at WOT ?
                    • Bullysteeth
                      • Jan 2012
                      • 830
                      ye, more under heavy load when i let off, i get the dv hissss not to loud, and the fuvv fuvv fuvv fuvvv type of noise !!!!
                      • Bullysteeth
                        • Jan 2012
                        • 830
                        have you checked the pipes bud, the return may have come loose
                        • driftin jo
                          • Sep 2007
                          • 2222
                          It's a diverter valve, when you shut the throttle it opens to allow air to flow form the turbo outlet back to the inlet to stop compressor from stalling, without it the pressure builds when you shut the throttle as the air has nowhere to go and stalls the turbo.
                          • Tony Stark
                            • Nov 2009
                            • 288
                            Thanks!
                            • audinut
                              • Jul 2009
                              • 2195
                              Bully get yourself a new valve as what your describing is why i changed mine.
                              Personally im not getting a chatter just a whoosh of air like a after market DV when i lift off the throttle mainly in 1st and 2nd gear - my 710 is approx a month old?
