rich running 3b coupe
  • prj
    • Mar 2010
    • 6308
    1. Pull fault codes.
    2. Get rid of cone filter and fit stock airbox. Cone filter on stock MAF will make your car use more fuel and will reduce performance.
    • simons2
      • Mar 2010
      • 344
      Will try that , car runs fine hot or cold
        Originally posted by ian4455
        My car seemed to run fine unit i upgraded to RS2 Hybrid spec 3b. Started ok when cold and drove ok until it started to get warn then black smoke & wouldn't tick over.
        Assuming you’ve cured it, what was the cause of the fault ?
        Thanks.
          If one doesn’t have Vag - com, what ohms reading should one be looking for with the big brown MFTS, and also the smaller two pin white one.
          When stone cold or warmed up ?
          Thanks.
          • simons2
            • Mar 2010
            • 344
            Not had time to look at it yet , she runs sweet as a nut hot or cold just rich with poor fuel consumption
