3b Pin Swap
  • ian4455
    • Nov 2010
    • 787
    3b Pin Swap
    I understand whats involved swapping pins in the ecu connector, but is this best done in the foot well of the car or should i remove the harness ?
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    in the foot
    • ian4455
      • Nov 2010
      • 787
      oh ....so its going to be a little awkward job. Do i need any special tool to remove the pins, also ref you post on pin swap which is the correct one to go off ? Think there was some adjustments, may need to read the thread again (getting wrong off my other half for being on here!)
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        yes it is not a very pleasure job to do
        but bit a bit without hurry it is perfectly done ( take 12 beers to share with your friends..)
        yes i used a special custom tool...to can remove the pins...it should be like a long neddle
        • rs200
          • May 2009
          • 1398
          • Home: Croatia
          it is very easy job to do.. (I did it on 4 cars).
          if you will need some advice just ask !
          take the pin out (which have to be out) , mark them with numbers. you also need 5 more wires for coils. and one wire for VSS . than use somebody who will read you numbers. for example :
          1 to 6
          5 to 4
          36 to 46
          don't turn head away from wires.
          VSS signal you will find on air condition conector
          when you will done , don't vory , because 2 wires from 3b loom will stay out. it is normal because ABY ecu don't need them .
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            You dont need numbers,just write It's colours
            And yes,It's much better to have a friend by you to help singing
            • rs200
              • May 2009
              • 1398
              • Home: Croatia
              my option is numbers. because I can lost myself in colors. brain demage 100%.
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                The drugs causes many problems in the brains
                • ian4455
                  • Nov 2010
                  • 787
                  1 to 6
                  5 to 4
                  36 to 46
                  I now see where the 12 beers come in ref to Rocco's suggestion, going to have to temp someone to read the numbers
                  What tool do i need to remove the pins, any pics ?
                  Page 8 on the sticky for Pin Swap is the correct pdf ?
                  The 4 wires not used can be used for coils, maybe best to pull through new wires ?
                  • rs200
                    • May 2009
                    • 1398
                    • Home: Croatia
                    2dl of STOCH is perfect for pin swap
                    use new wires directly to new coils.. use +'12V and ground from old coils for new coils . than it stay on old fuse.
                    ECU plastic conector is made by 3 pice. like sandwich , this tiny piece of plactic in the midle have to be broken. it is almost impossible to save them and take few wires out. only if you take all wires.
                    crush them with sizers for wires.
                    this white conector have black plastic cover which have metal locking spring. I cut them on half that I can take all wires out. it will be much easyer to work if you do this.
                    last one PDF file is 100 % ok.
                    maybe I can do new thread "DIY PIN SWAP 3B to AAN .
                    • rs200
                      • May 2009
                      • 1398
                      • Home: Croatia
                      this is tool which I use to take wires out from conector.
                      I put them in the whole in plastic conector , oposite side of wires, ank kick the plastic , than little ears of pin can pass out.
                      • ian4455
                        • Nov 2010
                        • 787
                        Thanks have a few of those screwdrivers, how about wire size to use for new coils ? Also is there a list of plugs i need for the 3b conversion to V8 coils, only found a list for aby or aan. Managed to get time to pull the plug apart..
                        • ian4455
                          • Nov 2010
                          • 787
                          1 to 6
                          5 to 4
                          36 to 46
                          Where do i get new pins for the ecu connector for the coils ?
                          • rs200
                            • May 2009
                            • 1398
                            • Home: Croatia
                            I use those wires from some old ABS loom.
                            • borderS2
                              • Jul 2008
                              • 166
                              Crimp pins from here?
                              http://uk.farnell.com/contacts
                              S2 91 (red standard)
