RS2 Diff indicator
  • wowow
    • 123
    • Country: Hong Kong
    RS2 Diff indicator
    My car only has the rear axle part lit up, does that mean it is not running 4wd? I see other rs2 had lights on both axle. When I press the diff lock, the abs off light comes on as it should. I don't think one can choose rwd and 4wd.
    ________________
    RS2-95
  • Mcstiff
    • Oct 2004
    • 504
    That button is to lock the diff (only an option for the rear in the B3/B4s) AWD is fulltime.
    1995 1PissedOff90sigpic1991 USDM CQ 7aT
      And the C4 UrS4s. As you say, quattro AWD is full time, even back with the B2s. The only difference was the B2s could lock the centre and rear diffs. That was before Torsen came in as the centre diff. With the Torsen centre diff, it is never locked. But the B3s, B4s and UrS4s could (and can still) lock their rear differentials to help extract the car out a sticky situation, from a standstill until 15 mph or so, when it is automatically disengaged.
      Here is a diagram of the mechanical parts of the RS2 rear differential locking parts.
      • wowow
        • 123
        sorry guys, i still don't get it. If its full time 4WD, then all the lights should be on, like that attached photo. But mine only show the rear 2 wheels. What is wrong ?
        ________________
        RS2-95
        • wowow
          • 123
          Here's a photo on my car :
          ________________
          RS2-95
          • psychokm
            • Aug 2011
            • 2
            • Home: Latvia Current: Denmark
            In my opinion you just have blown backlight bulb under the front axle drawing.
            • djh
              • Jun 2011
              • 1622
              • Home: United States Current: United Kingdom
              • Mcstiff
                • Oct 2004
                • 504
                Originally posted by UrS4boy
                And the C4 UrS4s.
                Why does everyone on the internet need to try and pick each other apart? It is one thing to comment on a flawed way of thinking or technical misstatement but can we at least try to comprehend what is typed before calling one and other out?
                I said locking the diff was "only an option for the rear in the B3/B4s" NOT [i]ONLY B3/B4s had the option of a rear locking diff.
                • aRtiS
                  • Nov 2008
                  • 989
                  • Country: Latvia
                  Change electric bulb and that's it
                  Audi RS2 600 hp
                  Audi S2 1200 hp
                  MB 230E '83
                  https://www.facebook.com/ventracing.lv/
                  • sam80quattro
                    • Oct 2006
                    • 1496
                    wowow there shold be a green light in the middle of the rear diff when its locked. as above, you have a blown bulb (or two)
                    • wowow
                      • 123
                      woosh, its comforting to know that its only the bulb and not the 4wd. Many thanks to everyone :-)
                      BTW, if indeed there is something wrong, will there be a warning signal somewhere ? In fact, my warning light "(!)" on the dashboard has been coming on intermittently while I was driving, but it doesn't tell me what's wrong. It comes on about every 2-3 minutes for 10 sec. Strange
                      ________________
                      RS2-95
                      • Azman
                        • 3205
                        Check the fluid level mate prob just on the level so triggering the alarm as you drive
                        Dark Grey Avant
                        RS2 FARB
                        Alloy Subframe Bushes
                        • hermanio
                          • Jan 2009
                          • 800
                          check fluid levels, or you might have a bad brake "bomb"
                          5 Cylinder Freak
                            I didn't contradict or call you out. I simply added information "And the C4 UrS4s" plus I added diagrams to help wowwow (and others) see how the system works.
                            • wowow
                              • 123
                              What is bad brake bomb ?
                              ________________
                              RS2-95
