boost leak finally found
  • dobbin
    • Jan 2011
    • 164
    finally found a boost leak ! after months of trying to find out why my rs2 wound not boost over 1.55 max and hold strong there ,( should be around 1.8 to 1.9 bar).
    after changing every small hose off the manifold which i did have small leaks ,
    today i spent over 2 hours spraying down every hose again and throttle body to find at 1.6 bar plus the isv valve was leaking from the back of the housing where the plastic housing fits to the outer casting (plug block).
    now can i strip it down and seal it up or just fit a new one ?
    by the way i could not hear any air leak at all up to 2 bar pressure only by spraying it
    with soapy water did it show.
    N71 Idle Speed Stabilization Valve (ISV or ISS Valve) Info
    Must be an internal leak past the ISV valve shaft seal. Doubt that you can fix it properly.
    Here is some ISV info, including Bosch PN:
    • s2driveruk
      • 12696
      good find, not seen that as a culprit before but one to add to the list of possibles now
      1992 3b S2 Coupe
      • madpugger
        • Sep 2007
        • 1901
        It always really confuses me how such a small leak can affect boost so badly, I mean if you look at the volume of air it takes to produce 1.9 Bar, how can a 'drop in the ocean' cause such grief?!
        Le Mans 2012
        Nurburgring 700
        1995 S2 Avant
        • s2driveruk
          • 12696
          yup....i had one in my IM casting and caused loads of grief!
          1992 3b S2 Coupe
          • QuattroFever
            • May 2006
            • 1360
            What IM oem?
            Volcano ABY coupe
            Ant
            • dkw_dude
              • 555
              • Country: Norway
              Had the same experience a few years ago, when pressure tested and sprayed with soap water the IAC produced bubbles @~1,5 Bar or so (from memory). Bought a new one, installed and pressure tested again and still bubbles. Maybe a little less, but still bubbles.
              Leif-Helge
              -91 S2 VEMS and Comp Turbo
              -12 B** 530XD Touring "S2 parts transporter, and daily driver"
              • prj
                • Mar 2010
                • 6308
                ISV's on all of these cars leak.
                Epoxy the back.
                  Prj,
                  Any photos of what you did with one of yours ?
                  Thanks.
                  • ChrisAudi80
                    • Oct 2011
                    • 236
                    • Home: Norway Current: Thailand
                    Epoxy the back.
                    Had the same thing recently. The idle was crap, too. Epoxied the back of the ISV.
                    Fixed.
                    '96 UrS6 auto PRJ chipped E85
                    '95 80Q AEB VEMS E85
