This was a quick writeup to show what is needed to fit the 2.5l coilpacks in a 3B valvecover. The MKVI 2.0TSI 06H905115 coilpacks just dont fit.
Also these newer taller coil packs are higher voltage and the 1.8t guys are opening up their plug gaps to .040 with no detonation!
x5 07K998715F - black VW 2.5 coilpacks. 06E905115 MKV 2.0TFSI for the red ones. the coil bodies look the same, but dont have one to try yet.
- Cut the 1" tall rubber seal ring off the tops.
- Grind down the plastic lip that now exposed from under the rubber.
- You will also need to grind off the plastic centering 'key'.
- Install
- Done
Even with all this trimming done it is still a snug fit. I do not plan on adding any kind of coil brackets to hold the coils down. I also used the valve cover studs for coils 2nd ground
how i did it
- Install
- Done
how i did it
