Updated Boost Control/WGFV Diagram
Nope. The spring keeps the valve CLOSED. Without pressure to the lower chamber there is NOTHING to open the WG valve.RS2'd 93 UrS4 5 spd sedan
There is actually.
Exhaust gas pressure does press on it from below, but that pressure is fairly negligible, because of the way it's oriented.
But if you would take the spring out for example, then the gases would push it open and you'd get no boost. Or if you would fit a 0.1 bar spring, it'd also push it open with just the pressure of the exhaust.
P.S. I know this is not very relevant, as no one is running anything less than 0.4 bar spring, but I thought it's correct to point out.Comment
