Head Off - AGAIN
  • Doug_RS2
    • 3847
    Marco - I see what you mean - it looks as if some of the sharp edges have been eaten(smoothly) away?
    I will have a close look tomorrow. I don't really want to take the pistons out, It was dark when I took the head off and I never looked at the bores - but the pics they look really shiney - no signs of the honing - is that correct? I did the "drive it hard witin 20 minutes of the car starting" method for bedding in the rings.
    Mark - I hope I don't put the AAN inlet manifold on and start getting the lean problems in 1 and 5 - I couldn't face taking the head off again!
    • Mark Halligan
      • 2001
      Yeah a similar thought has crossed my mind about putting it back on, but looking at my combustions chambers they are all similar in appearance...a little sooty if anything.
      I know its a PITA but if your pistons have been 'eroded' away a little on that sharp edge it would be a good idea to 'future proof' them by filing the edges away.
      Mark - Modded
      • caterpillar
        • 2480
        to pisobiker: what conrodlength are the Ibeamrods ,and who have maked those pistons,boresize expensive
        • Pisobiker
          • 1175
          Originally posted by Mark Halligan
          I was a bit pissed off and didn't check the gasket before I threw it in the bin
          I understand perfectly, Mark.....
          @ Doug,
          while there, take the sump off and get the pisotns out. I would.
          @ Dave,
          I'm finishing my house too. If we where neighbours we could have done a lot of fun stuff together....
          Marco
          • Pisobiker
            • 1175
            don't want to hijack Doug's therad so I'll be short:
            I was a little concerned about conrod lenght I requested to Pauter, because what I heard afterwards from other sources wasn't same as mine. But today I measured the deck height and it is perfect ... so my measurements where right (piston +0.02 mm over block deck):
            With AAT 95.5mm stroke block (same as AEL), OEM 3B-ABY-ADU piston's compression height,
            then conrod lenght = 155.8mm (I took into account a 0.1mm skimming off the cylinders, which I actually did).
            Cost for the JE set of pistons with moly+ceramic coating 1040 US$ + shipping.
            They are Ø 81.45 mm
            Marco
            P.S. If you guys have a little bit of patience I'll soon edit a detailed report of the stroker building.
            • Doug_RS2
              • 3847
              #21
              How did you guys do it? Hand file or or a stone on a drill?
              • Mark Halligan
                • 2001
                I used a smallish file set, mainly with a half round file.
                Mark - Modded
                • Pisobiker
                  • 1175
                  I did it using an air tool with a sand paper cutter. Takes a bit of caution this way, though, 'cause the air tool cuts metal away really fast. finished the edges with a half round hand file.
                  Marco
                  • Stick Insect
                    • Dec 2003
                    • 2338
                    Doug. if you have a oilstone and spray WD40 on it ( to stop clogging) you can use that, it gives a very controlled finish.
                    HTH
                    Marco, I'll move to Italy, the weather here is lousy. Barolo is cheaper over with you....
                    David
                    • Pisobiker
                      • 1175
                      Od?,tick Insect]
                      David[/QUOTE]
                      Lots of good places where to build houses around here. Std door height is 210 cm, so you should fit.....
                      Marco
                      • sal_s2
                        • 1287
                        Can any of you (Mark or Doug ) post a pic of what needs to be done to the pistons before I fit them please?
                        • Doug_RS2
                          • 3847
                          #27
                          Go here:
                          half way down there are 2 pictures of Marks pistons - it is filing down the sharp edge so youu have a flat edge that is about 2mm thick.
                          • Beetie
                            • Oct 2003
                            • 1517
                            Well hope it all goes together well and performs the way it did before..... Good luck!
                            • Doug_RS2
                              • 3847
                              #29
                              I hope it doesn't perform like before - it will perform a lot better this time - lots more advance (lower CR) and more lower down torque (changing turbo coldside).
                              • Mark Halligan
                                • 2001
                                Originally posted by Pisobiker
                                Mark do you have any better picture to show det. damage on the head? I was interested in seeing how it looked.
                                Any signs on the head gasket?
                                Marco
                                Marco, here is a better pic of one of the combustion chambers (after a light clean up) that had the det damaged pistons, nothing wrong with this one or the other, so looks like it was just the pistons with damage after all.
                                Mark - Modded
