JE piston advice please
  • 20Vcqdriver
    • 829
    After a year of saving I am now able to get the 82.5mm 8.5:1 pistons for this 7A block i have to replace the 3B one that is now a bit tired and not really up to the 420bhp aim.
    Question ,
    1. Has anyone used the JE pistons with the 'tuff skirt' coating?
    2. What benefit is there in fitting a reduced comp ratio to standard as they all appear to come with this.
    3. whats everyone using as a bore clearance with these, cheers..
    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
    2004 A4 2.5TDi convertible, re-mapped to 180bhp
    2011 A5 sportback 3TDi-Backbox delete, remap
  • 20Vcqdriver
    • 829
    Cannot believe no-one has used these tuff skirt pistons and been told to make the clearance slightly tighter than JE state too but not about to jump in without someones personal experience on both these points. Cheers
      Been covered before, there is a big thread on JE pistons and the piston clearances.
      On the Tuff Skirt dont use it, I was simple told you bore your block to the clearance of the pistons and what happens whn the coating wears off?, you get increased clearance.
        • 20Vcqdriver
          • 829
          Thanks for that, this thread didn't come up on my search, cheers.
