ABY - what blows first
  • adam g
    • Feb 2007
    • 445
    Whilst being really stupid today and going flat out on an engine that I hadnt had remapped since a 4 bar MAP sensor upgrade, I unsurprisingly blew it up.
    The good news is there isnt a rod hanging out the block but the massive smoke plumes (that accompany the massive misfire) come out of both the engine bay and exhaust.
    This suggests head gasket to me but I thought a head gasket would be eaten by mild detonation over time rather than a sudden 30psi blast. Also arent they metal on the ABY so should be pretty robust so mabey its a holed piston. Could it be something else I havent thought of?
    I intend to start pulling it apart tomorrow.
  • driftin jo
    • Sep 2007
    • 2222
    Your rods are probably bent.
    • madpugger
      • Sep 2007
      • 1901
      Knackered bore/piston I'd say...
      Le Mans 2012
      Nurburgring 700
      1995 S2 Avant
      • adam g
        • Feb 2007
        • 445
        Possibly but it still got me the 8 mile journey home. I would have thought bent rods would be an engine siezer.
        • martinws
          • Oct 2008
          • 917
          Where was the smoke coming from under the bonnet? what colour was the smoke?
          • driftin jo
            • Sep 2007
            • 2222
            No, it wouldn't necessarily seize the engine.
            • SteveH
              • 4460
              I badly bent three rods and the car still ran. Apart from a loud knocking there were no smoke or oil issues.
              91 Modded 3B
              14 A6 Avant Black Edition
              • rs200
                • May 2009
                • 1398
                • Home: Croatia
                bent rods 100%.
                same symptoms have my 3b before engine rebuilt !
                good luck !
                • JariP
                  • 192
                  Maybe a blown head gasket and melted cylinder head between two cylinders.
                  • adam g
                    • Feb 2007
                    • 445
                    I guess it makes sense that the ali head might melt before the gasket. Ar*e, this could be an expensive, me and my impatience.
                    The smoke is coming from somewhere under the exhaust manifold so hard to see but assume from between the head and block. The smoke was grey/blue and reeked of oil.
                    I'll start with compression check. How big a job is the head removal on these. Ive done a 10v URq head recon a few times. Is it a similar nightmare of a job on the ABY?
                    • JP
                      • 1858
                      Twice as bad as double the valves and half the space
                      UrS6 Stroker + HTA3586 =
                      • QuattroFever
                        • May 2006
                        • 1360
                        What reg aby is it. Didn't some early ones still come with the paper gasket.
                        Volcano ABY coupe
                        Ant
                        • adam g
                          • Feb 2007
                          • 445
                          Not sure of the year of engine as I bought it 2nd hand, its a conversion into my urq.
                          However, from the small piece thats visible it looks like a metal gasket.
                          A bigger job than the 10v then, awe bugg*r
                          • djh
                            • Jun 2011
                            • 1622
                            taking the head off ain't too bad on these, i'd rather do one of these than a 10v.
                            • DJones
                              • Jun 2005
                              • 2020
                              Ditto^^
