Before another thread descends into chaos...
I think that, to summarise: vent to atmosphere valve are not correct for these cars (when retaining the MAF in the OE position) but that if you want to accept that they're not correct and decide to use one, then minimising the amount of air lost in each dump is essential to minimise the negative effect on the way the car runs and also the harm and any longer term damage due to bore wash etc. that might be caused my the momentary rich running.
My GFB had 13 adjustment positions, of which the middle 9 changed the aperture hole to atmosphere (so positions 2 fully closed -11 fully open). Anything over level 4 could be felt in the form of a flat throttle response when changing gear and heard in the form of the car popping on WOT gear changes. I ran it on level 13 only once and kept it on level 3 for the rest of the time, leaving an aperture ~10% of the full size. This gave a small gain in noise and no noticeable change in throttle response. Level 13 was hilariously loud but the car felt off form, so I reverted back to my Forge 007. I'd like to try and APR R1 next, to see if they offer any improvement over the Forge at 2x the cost.
FFFFSSSSssssssssssst!
