I've fitted the correct Bosch spark plugs today. It had some NGK PFR7B things in there. Anybody know if you can get the rubber boots which fit over the plugs separately ? The ends on a couple of mine have split or broken off resulting in a bit of oil around one of the plugs.
I also stripped down the brakes today as the n/s/r pads were binding. Just like the fronts were a couple of weeks ago. New damping plates and a thorough clean and they're now working perfectly & blissfully silent
I'm gradually getting everything fixed. Leaking clutch slave cylinder is next and an oil & filter change as somebody had fitted a Motaquip filter
.I'm gradually getting everything fixed. Leaking clutch slave cylinder is next and an oil & filter change as somebody had fitted a Motaquip filter
