the new cabby has a couple of annoying engine probs,
1)Wont rev over 5k when under load
2)Annoying rattly tappet.
I have bought some expensive hydraulic valve lifter oil but it doesn't seem to of helped,but then tonight gave it a proper thrashing on a private road and it was a bit quiter.Eventually hauled it up to 120 and it would not go over 5k.
Replaced the cap + Rotar arm,it has fresh oil in it etc.Suspect it may be a timing issue but cant seem to be able to tell if its pinking or just the loud tappet!
AArh! At least its a lot better on fuel than the S2
