Turbo Suggestion
  • Quattro GmbH
    • Mar 2012
    • 18
    • Country: South Africa
    Turbo Suggestion
    Hi
    I've got a stock RS2 and have ordered VEMS and 550cc injectors. Someone recommended a Garrett GTX3076R, But I came across a GT3040R which looks very promising!!
    Here is a link of this turbo:
    Can someone tel me if this will have a good ratio between lag and power?
  • Quattro GmbH
    • Mar 2012
    • 18
    And I can choose the K24 housing and just bolt it onto the stock manifold!! I think . . . . .
    • Ross
      • Aug 2005
      • 3399
      You'll also need custom oil and coolant lines for any of the Garrett turbo's, the K26 hotside is direct fit to the manifold but not perfect - on my GT3071 I had to space up the engine mount to stop it resting on the chassis and alter the downpipe as it sits about 1/2" further back.
      I would be going for the GTX3076R, it's a newer and improved turbo - you'll get boost sooner, better low-boost performance and similar power... the injectors will limit you to ~550hp anyway.
        No no no to a 30/40 a gtx3076r would make more power than it as well
