Water / Meth injection details
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    #31
    And you Dmitri?
    • prj
      • Mar 2010
      • 6308
      Originally posted by Rocco
      And you Dmitri?
      I run 1100cc with 50% meth.
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        #33
        Gay....
        85/15 % is for men.
        Serious,why don't you go richer in % meth if you know that is better for cooling and power?
        • prj
          • Mar 2010
          • 6308
          Gay....
          85/15 % is for men.
          1. It quickly becomes very flammable.
          2. I use the windshield wiper tank and special -40C windshield wiper fluid that contains meth 50% by volume. If I used anything else, I would have nothing to wash my windscreen with.
          • urs4guy
            • Dec 2007
            • 192
            Does anyone using meth have any IAT logs? Here's one Edigreg posted in a Motorgeek thread:
            This was with a stock K-24 turbo at high boost.
            This is a log from my 034 Iic:
            MAT--manifold air temp
            CLT---coolant temp
            That run peaked at 30 lbs. Notice how linear the temp is and how it decreases during the pull. Also of note is the very flat coolant temp graph. Attributable to many things including the big oil cooler and the custom Ron Davis radiator. My car uses a NOS serpentine spray bar in front of my FMIC. The other guys are using W/M injection.
            Hap, wit dakine coolness not from Evahboost, Maguire
            • prj
              • Mar 2010
              • 6308
              On my RS4.
              Without meth 3rd gear pull 30-55
              With meth 3rd gear pull 28-31.
              • blackS2
                • Apr 2010
                • 455
                on S2 Gt35
                without meth up to 57°c
                with 50/50 up to 32°c
                [__]=oooo=[__]
                  Mine is a basic system which comes on at about 1 bar.
                  Originally posted by Jonas_R
                  @Greg & Djones
                  You guys run a progressive system or just an on/off system?
                  @prj
                  do you know if a6 2.7t ecu can be made to control a valve like the rs4 flap valve?
