The smaller of the two, single pin output located just above the larger two pin sender. I'm 99% sure will sort your problem as long as you have tested pressure with a proper gauge.
Check the connection to the sender first, it could have just come off.
Err, if you're getting the warning regardless of RPM then it's the lower (pressure) of the two low pressure oil switches that's playing up and that one is combined with the oil pressure sender so it's the larger of the two sensors on the block behind the water pump with two connections on it.
For this oil pressure switch you can test it by disconnecting the wire to it and seeing if the warning goes away - always assuming you really do have oil pressure!
Fair play, your right. I stand corrected. Must engage brain before posting, had only had one cup of Coffee at 8.30, thought the single pin was the low pressure switch but it's not.
And yes you can test this one by disconnecting it as described above.
Reason: more info
Not exactly but I did get round the problem by replacing the combined oil pressure sender and low pressure switch unit with a "t" piece into the block and then fitting a seperate oil pressure sender - that came with a Glowshift 270 degree oil pressure gauge and a seperate low pressure switch. Mine came from a mini but a standard VAG switch from a Polo or Golf would do.
nice solution, I guess to retain the OE VDO's we'd need to find a sender with the same voltage range?
IIRC AndyP tried an aftermarket VDO one, but there were issues fitting it? Wonder how he go on..
I'm sure he will be along shortly
That's a great price, however it's not a genuine VDO unit which puts me off a little. That said they could be fine, anyone heard of 'FAE', their not a manufacturer I'm familiar with.
They've been around since the 50's. It's a spanish company based in Barcelona.
They only do car electronics, and have got a ISO 9001 and a ISO 14001.
I've already bought one, so I'll let you know how it works
If at first you don't succeed, destroy all evidence that you tried.
Replaced mine with the FAE part linked above. Works fine so far. I have my doubts that it will work for 15+ years as did the last one, but if I get 5 years out of it im good.
