Poor warm starting S2 ABY
  • hermanio
    • Jan 2009
    • 800
    i have a problem with my s2 ABY, when the engine is cold it will start fine. when its warm it will also start fine, but when the car has sat for let say half an hour, its much harder to start the car. i cleaned the injectors but it didnt help, checked the G62 temp sensor with a multimeter and it was fine. does anyone know what can cause this problem ?
    5 Cylinder Freak
    Hall sensor is on it's way out and needs changing. Common issue on ABY be careful it will get to the point where it wont start at all when warm.
    If you do get stuck you can try the cold water down the cam cover trick
    • hermanio
      • Jan 2009
      • 800
      forget to say, that was the first thing i replaced, didnt help..
      5 Cylinder Freak
      • hermanio
        • Jan 2009
        • 800
        the strange thing is that i only have the problem when the car has cooled down a bit, when its warm ist start fine. i thought maybe my fuel injectors were leaking when i shut down the car, but cleaning them didnt help. you should say its a fuel issue because when i try to start the car i seemes like the car gets to much fuel, a little trottle will help then but it still wont start like it should
        5 Cylinder Freak
        • hermanio
          • Jan 2009
          • 800
          also no fault codes
          5 Cylinder Freak
          • Monkeymagic
            • Mar 2012
            • 3419
            Possibly leaking injectors causing engine to lock up a little? I suffered a hot start problem with my MK2 Golf for ages after a 2 litre conversion changed all manner of things. Turned out to be the negative battery terminal to the block going high resistance when hot. Changed for a thicker one and never struggled since.
            I'm no expert with S2's but is it a possibility?
            • hermanio
              • Jan 2009
              • 800
              thanks for you reply but i dont think thats the problem, because when the car is hot it start fine. only when you wait for half an hour it doenst start good, like the mixture is to rich
              5 Cylinder Freak
              • Monkeymagic
                • Mar 2012
                • 3419
                If it's struggling to crank over i would suspect injectors leaking. Try recreating the problem but remove the plugs.
                • hermanio
                  • Jan 2009
                  • 800
                  i made a video of the problem, car is warm and sat for half an hour. when the car start you can hear a bubbling sound for the tank, you can only hear this when the car start bad.
                  5 Cylinder Freak
                  • driftin jo
                    • Sep 2007
                    • 2222
                    Maybe your check valve is dead.
                    If so the heat would make you loose pressure when you shut off .
                    • driftin jo
                      • Sep 2007
                      • 2222
                      You could check if it this by running the pump for a few seconds
                      before trying to start it, just run a wire to the pump.
                      I fitted a push switch as when i fitted an aftwrmarket
                      pump it had no check valve and i had similar issue .
                      • hermanio
                        • Jan 2009
                        • 800
                        check valve is at the fuel pump isnt it ? pump is cooled by the petrol so would heat effect the valve ?
                        5 Cylinder Freak
                        • driftin jo
                          • Sep 2007
                          • 2222
                          Heat will help push the fuel back to the tank if the tank check
                          valve is no good
                          • hermanio
                            • Jan 2009
                            • 800
                            ive tryed running the fuel pump for a few seconds with a cable before i start the engine, but there was no difference
                            5 Cylinder Freak
                            • driftin jo
                              • Sep 2007
                              • 2222
                              it's not the check valve then, at least you have ruled that out.
